EA Orders Don't Process Through Beta App
Hi, beta crew!
You shouldn’t be able to make EA orders through the beta app. So if you’re wanting to get in on this sweet, sweet Wyze Lock action, please go to wyze.com to make sure nothing funky ends up happening to your order. :slight_smile:
I was able to make an order through the beta app., and my CC was charged. Did it go through? Do you need the order number generated?
Same here. CC has been charged.
If your card was charged, you’re probably fine. But you may want to check with the support team just to be on the safe side. :slight_smile:
Support Request Form
