Hi, Looking to see if it is possible to improve on the webview (windows version, there wasn’t a tag for windows that I could find) for this camera? In webview Events, currently it gives you the two camera view, one over the other, both sized the same smaller size. Is it possible to get a large main camera view with a small “picture in a picture” view like when you view the live view? This would allow for a much clearer viewing of Events as currently the main camera view in events is too small to see real details properly (and you don’t really have a decent zoom feature in webview other than the less than desirable built-in zoom the windows has…). Thanking you in advance, Stan…
In addition to what you’re asking about, I can imagine a feature in Web View that would treat the cameras independently so that you could select and view each at the same size “tile” as any other Wyze Cam. I don’t have a Duo Cam Doorbell, but these suggestions seem like they’d be good additions to this existing Wishlist topic:
In that or other topics in the Wishlist category, you can click or tap the Vote button above the initial post and then add your ideas and use cases to the replies to show your support.
There’s no tag for that, but there is a web-view tag that you could add to your topic. If the Forum platform won’t allow you to do that, then you can also flag your own topic, select the Something Else option, and send a note to the Moderators team and ask them to add it. Thanks for using the tags! ![]()
