Wyze really needs to make itpossible to view the Duo Cam Doorbell at a larger scale by default. There is no way to hide the recent events below the image. The only option is to select one of the cameras which then zooms in too far, requiring a zoom out.
Even pulling on the bar below the image does this by default.
Wyze, plase just give us a full screen view or (close to that) when we don’t require all the stuff below the video. Like when we just want to see the live view.
On the Duo Doorbell view, if you tap on the smaller image, it will swap with the full screen. In addition, you can tap hold and drag the little window around the screen. It is not fixed to that position.
Also note, when you are in the split view, pic 2 in your images, you can double tap on one of the views to fill your screen. Double tap again and it goes back to the default view
Wyze really needs to improve the Duo Cam Doorbell live view. It would be much better if we could see the video in a larger or full-screen view by default.
Right now, the recent events always appear below the video, and selecting one camera zooms in too much, so you have to zoom back out. Even dragging the bar below the video causes the same issue.
Wyze, please add a simple full-screen or larger live-view option for users who just want to see the camera feed without all the extra information underneath.
[Mod Note]:Post moved to more relevant existing topic discussing this same product and/or issue for better visibility within the community.
