Dual Door Bell Parts
The tiny locking part that falls out of the dual doorbell cam making it useless that tiny little thing have somebody replicated and launch it up on bambu handy so we can 3D print them out what a hassle i spent ton of money for that it’s garbage because of a tiny 11 millionth of a cent part
Welcome @911plow
Which Locking part are you talking about? The part that locks the Dual Doorbell to the plate?
I do 3D Printing and have an ability to create parts, as I have done in the past. If it is something that I can create, I would be glad to
When you push the Unlock Pin thru the top hole to unlock it’s the tiny piece you push down to unlock. It fits into a small square hole . The “tiny clip” or small plastic piece you’re describing is almost certainly related to the locking/release mechanism on the mounting bracket (back plate).
What Likely Happened
Wyze doorbells snap onto a wall plate or angled wedge with plastic tabs/clips or hooks at the bottom and a locking tab at the top. To remove the camera unit, you typically:
Insert a thin tool (the included Doorbell Detaching Pin for newer Duo models, or a paperclip/SIM eject tool for others) into a small pinhole at the top of the doorbell.
This pushes a small internal release lever or tab inside the mechanism.
This is a known weak point in the design for some Wyze doorbells (the clips/tabs aren’t super robust after repeated removals for charging).
A part this small and unreliable ( charged 4 times ) before failure could be added to Bambu Handy for free prints or add 4 extra in box.
Thank you !!!
I will be packing up and returning and buying something else. Even though I do like but without that piece is no good.
Welcome to the Forum, @911plow! :wave:
What did Wyze Support say when you contacted them about the failed part?
