Can the door bell be removed easily to press the set up button?
If you mount the Video Doorbell v2 using the included bracket, then, yes, it just slides up and off the bracket. (Mine…not so much, but it’s in a 3D-printed enclosure that also covers the microSD card slot, so it requires the removal of a couple of extra screws.)
