Wondering you guys could help, my video doorbell pro has progressively gotten worse and worse at connecting. When I get a notification, I click it, and it can take 30s to…an indefinite amount of time to connect. It keeps cycling, trying to connect. I can close the app and try again…same. Typically the person there has left by the time it connects. Now this can be when I’m remote, or from inside the house on the same wifi…it’s just slow. Even my Google home just errors out cause it takes soo long.
chooka505, a doorbell that gets slower over time while the rest of your network is fine usually points at the 2.4 GHz link or the doorbell power. Two things I would check. First, open the doorbell in the app, go to Settings, Device Info, and look at the signal strength (RSSI). If it is worse than about -70 dBm, the doorbell is struggling to hold a connection and wakes up slowly, so try a closer access point or mesh node, and set your router’s 2.4 GHz band to a fixed channel (1, 6 or 11) with a 20 MHz width instead of auto. Second, check the voltage at the doorbell. The Pro needs a transformer of 16 to 24 V AC, and a weak one makes it drop and reconnect more as it ages. A multimeter on the wires at the doorbell will tell you quickly. What does your signal reading show?
