Doorbell Duo connectivity issue and the demand for human intervention
I have a hardwired Doorbell Duo on v1.0.24.37 (latest). Running Wyze App v3.13.0.784 (latest) on a Galaxy Tab A7 Lite on Android 14. It is on 2.4Ghz WiFi and sees 2 of 3 bars. I have both the camera and the tablet on fixed DHCP from the router, so the devices get the same IP address every time.
I run the wyze app all the time on the tablet to monitor the front door. The cam works perfectly in all respects but will not stay connected.
It was fine for about 2 weeks. Now, about every couple hours it disconnects with error codes 20006 or 20216 (indicating an inability to reach the servers or cloud). When I click troublehoot/reconnect, it instantly reconnects with no problem.
I’ve run through all the usual troubleshooting steps…and can’t get it fixed. But I have a bigger question…one for the developers if any ever browse these topics…if I’m able to manually reconnect so easily, why isn’t the App able to do this on it’s own? It seems to me, if can always instantly get reconnected…why isn’t the App taking this action itself? Why is it giving up and making me press a button?
Although you mention 2 or 3 bars on the wi-fi signal, and immediately reconnecting with manual intervention, can you post info on your gateway/router or access point you are using for your network. I’m thinking a potential glitch with the doorbell.
I have 2 vdb duos purchased at the same time. 1 immediately connects and begins livestreaming without fail. The 2nd vdb duo frequently fails at beginning the livestream and freezes at the 3rd step. No error, just freezes. I have to do a restart for the db to recycle and livestream. On a rare occasion it will complete connecting and start the livestream but more often not. It’s annoying but in my opinion an internal failure of the doorbell. Not worth the effort to try and find out since all other features work.
My duos are also hardwired which supports maintaining the battery charge not the functions of the duo. (A common misunderstanding of the hardwired state.)
are running the chime controller on this by chance? I figured out the issue I was having and im wondering if yours is similar.
Welcome to the Forum, @2Sheds_Jackson! :wave:
Or should I say “Arthur”? :wink:
That can happen, but my understanding is that whether or not this happens is unpredictable, and some developers and product managers choose to engage here more than others. As the Forum is primarily a user-to-user support community, your best bet for contacting Wyze directly is likely going to be through the Help Center.
In the case of the error messages you’re reporting, I’d be inclined to submit an app log after replicating the issue and then optionally create a ticket afterward (note that these are not the same thing).
You can also watch the Forum’s Wyze News category for app and firmware announcements (you can subscribe to these using the Forum’s Emails and Tracking settings if you just want to be e-mailed when, for example, a new Wyze News topic is created) if you don’t want to take the time to visit the Forum regularly, or you can check that category if you see the app offer you a new version. Since only Wyze employees are allowed to create topics in that category, replies in those topics are expected to get better visibility from Wyze, so that’s another way to potentially let them know of a problem. You’d still want to submit logs when doing that and then note the Log IDs in any related replies you make.
nope - I don’t have a chime controller
Thanks for the advice. I’ll keep poking at this problem and see how it goes. I’ll post if I find a fix/solution.
Do you happen to know much about the wiring Thatthe cam is currently running on? I have found that with the advance in technology that the duo has it makes it more susceptible to what is called ghost voltage. With my setup when I put the wiring in the wall I did not know about ghost voltage and apparently because my doorbell wires run down the wall next to some light switch wearing for my kitchen the wiring for the doorbell is actually picking up this voltage. I originally thought that my transformer was going bad because after having the same connection issues I checked the voltage ratings at the doorbell wiring and found that they were way higher than they should be! well lo and behold in my research I’m finding that wires even the wires I thought were shielded are still picking up ghost voltage and although they are not directly connected are still sharing some charge. I’m planning on getting a Triumph controller as talking to a few friends that are knowledgeable and such things it acts as a buffer and actually will stop the surges which are causing the issues. If you happen to know what your wearing situation looks like maybe you are seeing the same thing. If your doorbell lines are running next to any other power lines I’m guessing that is what you are experiencing as well. If you’re not handy with a voltmeter I would highly recommend having an electrician come out and check it out if you know or can get ahold of any.
Interesting comments about ghost voltage and its effect on your doorbell. My front and back duos have literally the same wiring setup. Both are back to back with inside light switches for inside and outside lights. Chime controllers are installed and transformer is 24/40 voltage rated. The 1 distinction between them is the front doorbell is located a shorter distance from the chimebox than the rear doorbell and is the one freezing at step 3 of the connection phase of livestreaming. Mechanical chime ding and ding dong correctly and batteries stay fully charged. No question my setup is properly installed.
I still believe my conclusion of an internal glitch or circuitry fault of the doorbell is the cause.
Very fair, But from what I’m reading it doesn’t take much to throw them off and it could just be a short term run in voltage that pops up then mess it up. You Seem to be pretty knowledgeable, you could always check it with voltmeter and see if you’re getting more voltage than your transformers putting out. That would tell you for sure. That’s what I had to resort to. And man was I blown away when I got that higher reading lol
I need to get a chime controller to kind of act as a buffer or resistor and see how that works soon.
If it’s internal circuitry though, you should see the same issues if you only run down the battery, you could also troubleshoot it that way.
I’ll post numbers from my multimeter the next time it happens (which is often) and I feel like unmounting the doorbell to measure at the terminals. I don’t think a measure at the chimebox terminals is needed since the issue is at the doorbell and wiring voltage to it. Depending on voltage results I may include the chimebox terminal measure.
you are spot on there!
For the past several days the doorbell has not been freezing at step 3 of authentication process to livestreaming. I did measure the the voltage however and came up with the following numbers:
Transformer- rated 24/40 measure 27.6v
Doorbell terminals- measure 26.6v
Accuracy rating is +/- 1.0%
I wanted to measure the doorbell terminals during a step 3 freeze but will have to wait for that to happen again and then I’ll measure it again.
Voltage at the doorbell would be ruled out with these numbers.
Sorry it took me a few days to respond, you just hit the response button I wasn’t tagged I didn’t know anything had come in LOL Looks like you did some excellent measurements and I wish mine were that good! see if you can get it to replicate as you stated it is running by other wiring Turn those lights on and off a few times and make sure there’s power being transferred back and forth in their lines and see if the ghost voltage doesn’t knock it off. You could always try measuring it while having someone else hit the lights too and see if you get any fluctuations. It looks like you’re on top of everything though. But right now that’s all that’s coming to mind. I’ll do a little more hunting and see what I can find, but I will keep track on this one and see if you post back. Again sorry for the delay :slight_smile:
Update from OP. First, I tried adding the WYZE chime controller. Ran for a couple of days, and this did not make any difference…continued to get 20162 disconnects that would manually reconnect. Next, replaced the 70’s vintage doorbell transformer (NuTone 16v, 10VA) with new Amazon unit (16-20v, 30VA). Ran 2 days, no difference. Next, completely disconnected the chime, so the new transformer is ONLY running the doorbell cam and nothing else…still get the same disconnects. With this setup, I see 17VAC at the doorbell, which should be adequate. One odd thing - although I do see the “charge” indicator on the app while connected to the transformer - the battery still runs down. After several days, if I disconnect the transformer, the battery is nearly dead…it’s obviously not charging. Should this not be maintained near 100% if it’s on the transformer all the time?
I agree that it should. The new transformer is adequate for a single vdb duo and it’s purpose is to charge the battery in the duo. When you disconnected the chime and went directly to the doorbell, I assume the connections happened in the chimebox. Have you measured voltage from the wiring in the chimebox? This does not sound like a faulty vdb duo. Does the transformer share a breaker in your electrical panel or is it connected via another source, e.g. basement light fixture box?
There appears to be a temp power failure pre or post transformer connection or perhaps wiring fault causing a temporary power failure. Would really like to know more about the transformer install. Can you provide an update on that part of the electrical setup.
I think that’s a good observation and would be important to clarify that the chime is being bypassed and that an unbroken/closed circuit still exists between the Duo Cam Doorbell and the transformer in the scenario where the chime is disconnected. :+1:
It would be good to measure/confirm voltage at the doorbell button location after disconnecting the chime to ensure that the device will receive adequate power to charge/maintain the battery.
