I’ve updated my Doorbell to the latest firmware to attempt to get Echo Show stream/viewing and routines working…
After doing this upgrade… the camera has extra steps to connect, ie:
Connecting cycle, gets to 2 or possibly 3 then starts again, and then retries, and then connects.
Sometimes its fine…and connects fine…right away with out issue…
Yes, I am going to say it… this was NOT AN ISSUE BEFORE the FIRMWARE UPDATE.
I have an Outlet Outside from 2 years ago, in the same spot, and it works 100%.
ALL Wyze devices on on A DEDICATED 2.4Ghz AP wired back to my router. The AP is about 25feet max from the doorbell to the AP… And again, Outlet Outdoor sits ON THE GROUND and has worked from this same setup for 2 years now… Not missed a beat.
This issue came AFTER the firmware update, and still no Echo Show access ( YES I am beating that drum, as I am quite annoyed with this right now )
Any one else seeing this on the doorbell?? Cameras V3 with light sockets, floodlight or garage controller do not exhibit this behavior.
The reason why you’re having your issue is because of voltage. Well the device may turn on insufficient voltage will cause issues like the one you’re having. Either the The transformer The Powers doorbell is insufficient most likely 16 v 10 VA. Swap it out with a 16v 30 VA from home Depot or online. To confirm that this is what you need check it out the multimeter.
I am running the same firmware version on the same app version on Android 13 for Moto and experience near instantaneous load to live stream from both the Home Device List and when the cam is grouped. I cannot replicate what you are experiencing.
My only suggestions, which are more standard troubleshooting steps than possible solutions, would be to (1) power cycle the doorbell, or (2) uninstall and reinstall the app, or (3) uninstall and reinstall the doorbell. The last would be to contact Customer Support and log a Support Ticket.
