Does V3 connect to base station
Does the V3 connect to the base station?
I want to put my V3 near my garage but it doesn’t reach the WiFi. So can I buy the base station and have the V3 work that way?
The V3 is WiFi only, like the V2.
There are solutions here for detached buildings. Powerline adapters to a garage WAP, microwave relays, WiFi extenders, cellular hotspots, and other solutions that can get you a garage WiFi signal.
Tell us a little about your situation, like how far your garage is from your router, and from the side of your house facing it. Someone here may have a solution that fits your situation.
No, there is no base station that works with V3 cams. They connect directly to your WiFi network router.
The Sense V1/V2, Lock, and Ourdoor Cam have base stations only.
You could try extending your WiFi network, depending on how far away your garage is.
If you were looking to buy the base station anyway to fix this, you could most likely but a cheap-ish router and set it up as a wireless bridge access point. Routers tend to have better wifi signal than something as small as a camera, so it’ll probably be able to connect fine out there.
Finally… the rioting makes sense. :smile:
Haha. I edited it. That’s a funny auto correct though
