Does the Wyze Duo Cam Doorbell support PIP mode?
Hi there. I am considering the Wyze Dual Cam Doorbell.
Does it currently support PiP mode in the Wyze app or as a floating PiP window on iOS/Android?
Hello @jay9502022
The default view of the Duo Doorbell is side by side (top/bottom). However, if you go into full screen view on either of the cameras you will enter a floating PiP view, the PiP can move moved on the screen. Which you are able to toggle quickly simply by pressing the PiP camera.
This operates the same on Android and iOS.
Hope this helps
