PIP capability all camera models
Please consider adding PIP options for cameras other than OG and OG Telephoto.
I have attached OG Telephoto’s to the side of few of my Pan V3’s, which works quite well as an alternative to other manufacturers dual-lens offerings. The only missing piece to this puzzle is the ability to view the Telephoto while moving the Pan.
The V4, V3pro and floodlight pro have P-I-P. You can’t just add the software feature if the hardware isn’t capable.
Ok. I see that these models have P-I-P for navigating away from the app. What I’m talking about is the ability to view two cams at once as is the case for the OG/OG Telephoto. Hoping for this capability to be added to the Pan V3.
Add bulb cam to the pip list.
There’s an existing Wishlist topic for this…sorta:
I don’t see anyone asking for the Cam OG in-app PiP experience to be applied to other camera models, but there are the requests for the opposite in that topic (i.e., wanting the Cam OG PiP experience to be the same that other Cams have, with a floating window available when the Wyze app is minimized).
@ssummerlin, Bulb Cam does the same PiP as some other non-OG Wyze Cams do (like Cam v4). There should be an icon on the screen in live view near the upper-right that looks similar to this:
Picture-in-Picture
Sorry. I knew that. I meant to say add WBC to the cams having PIP.
Oh, gotcha. I thought you were indicating that Bulb Cam should be added to the request.
