Does the OG Camera work with the Wyze Lamp Socket?
Just curious, if the Lamp Socket will adequately power the Cam-OG.
Yes, it will POWER the OG cam, but the OG cam won’t be able to pair with, or control it. So this is perfect if you don’t care about the OG controlling it, especially if you have the lamp socket paired by Bluetooth to another Wyze lamp socket that is controlled by a V3.
