Wyze lamp socket for OG cameras and telephoto OG a better way to connect them when there’s no outdoor power outlet.
Welcome to the Wyze User Community Forum @myklobito!
It is possible to use the Lamp Socket to power the OG. However, you cannot use the OG to control the socket.
The current Wyze Lamp Socket is an accessory to the Cam V3 and only the V3. This is because the V3 is the only cam with the firmware to operate the Lamp Socket. All other cams, including the OG Cams, are incompatible with the Lamp Socket controls.
The recommended outdoor power source for the OG Cams is the Outdoor Power Adapter.
If a bulb socket is the most convenient source of power, there are other ways to adapt the socket to provide the necessary power output for the OG and other cams.
If this is a request for product development, a new topic request needs to be made in the Wishlist category or posted to an existing request topic in that category. Refer to this topic:
A cursory search of the Wishlist resulted in the following topic which may suit your request. Follow the link, vote for it at the top,
like some posts, and add your reply post.
