Does the leak sensor work with IFTTT
The title says it all: can I use the IFTTT if the a leak is detected?
Reason I am looking into this: I have a third party connected water main valve, and I want to shut off the main if a leak is detected.
Yes please, IFTTT + leak sensor.
I could also use a leak trigger for IFTTT. Right now I use it to turn on a light bulb in the wyze app using rules. I then use that to trigger IFTTT.
