Do the most basic features work on WCO?
I turn off the WCO while going garden work to keep the battery life high but since the latest update, even when I turn the WCO off from the app, it still detects motion.
Also what’s up with the device WiFi arbitration? I lost power to my base for about 30 mins and the WCO battery plummeted from 86% to 55%. I really hope these major issues are worked out in next update
I never turn my WCO if I am going to be walking around in front of them for a long time, I just go to the settings and turn off event recording. The battery probably went down because the cam was searching for the Wi-Fi signal like it is supposed to do. If you have a weak signal the battery will also go down faster than normal.
