Do the Battery cam pro ever need manual reboots?
Thought you said it was common. How about non-Wyze swappable batterie cams?
Sort of off topic, and I agree that they seem to be a solid, will engineered battery camera, but I and others are experiencing issues where the Battery Cam Pro’s are NOT recording to the cloud when they should be. Makes me wonder what my four Battery Cams are missing, see thread at:
Wireless Camera not picking up movement
Back on topic, I’ve a Battery Cam Pro and WCO v2 down a hill about a 100 feet from the house for over a month now, connected to Wyze Solar Panels, and, so far both batteries are maintained by the Solar panels, and neither has ā€˜locked up’ requiring laying of hands on them yet.
I did, You didn’t say in Wyze cams, you said in wifi cams. Wyze’s only current battery cam (as well as the battery doorbells) have swappable batteries.
Ring, Lorex, and Blink are all ones that come to mind that have it also. I’m sure there are a dozen more on google.
While I don’t see it for sale on the main Wyze.com site, I do still see the older Wyze Cam Outdoor (WCO v2) available in the Wyze store on Amazon. Oddly enough, I’ve a WCO v2 that is doing better at detecting deer properly in a field right now, than the newer ā€˜better’ Battery Cam Pro. They both have different ā€˜feature sets’ that may or may not be preferable for one’s use case. The WCO v2 (and v1) are discontinued models.
Wyze Cam Outdoor Starter Bundle v2 on Amazon
Yeah by ā€œoffered by Wyzeā€ I mean current models that haven’t gone end of sale. It is still possible to get the older models, but honestly the whole ā€œbase stationā€ model seems to be problematic for many and those cams don’t have as many features as the BCP.
I agree that the Base Station used by the WCO v1 & v2 is ā€˜kludgy’, but it is that kludgy Base Station with a fairly newly purchased from Amazon WCO v2 that is documenting the issue I am seeing with the Battery Cam Pro issue I am experiencing (and others have posted about).
In Summary, I have a WCO v2 and a Battery Cam Pro, both connected to its own Wyze Solar Panel, both camera’s side by side, pointed in the same direction. Last night, I had another instance where the Battery Cam Pro is failing to record to the cloud or SD Card, a Deer slowly grazing literally in front of both cameras.
The ā€˜older technology’ WCO v2 gladly recorded to the cloud the slow movement of that deer:
i’ve 7 WCO v1s as well, and they actually serve a purpose for my use case as well. If I ever come across WCO v2’s for sale, depending on the condition of them, I’d still consider keeping them in service for how I use them. (like for keeping tabs on the problems my Battery Cam Pro’s are currently experiencing :slight_smile: )
I know people have been complaining about some of the cams no longer detecting wildlife as pets. Maybe the WCO isn’t getting the algorithm updates or something.
Guess it depends on what OP is looking to capture.
