Do all cameras work with cam plus?
Hi, I am thinking of taking advantage of the $7.99 offer for unlimited cam plus. But I want to make sure they work with all the cameras. Most of my cameras are generation one like the pan cam and the outdoor cam. I just want to make sure they all are cam plus capable, And after searching for 20 minutes on the web site, I could not find that info. I thought I would call, but I don’t have three days to wait on hold. Thanks for any help.
The Version One WYZE Cam Outdoor will work with Cam Plus for sure, I had it on mine for about 6 months. If you use cam plus there will be no more backup to the base SD card if you have been using that feature,
List of cams that can use Cam Plus.
Thanks for the link, that is exactly what I was looking for. I know it works on the outdoor cams, but I was not sure bout the pan cams as I have the first version of them.
I get a kick out of this company, they say
“UNLIMITED CLOUD BIDEO STORAGE FOR UNLIMITED CAMERAS”
Then you go down to the bottom and it says:
*Limit of 99 cameras on unlimited plan
*Cloud storage is limited to rolling 14-days
Some one should get them a dictionary.
Yeah, the word “unlimited” is meaningless in the United States (i.e. “Unlimited” cell phone plans… LOL).
I haven’t found a cam yet that doesn’t work with Cam Plus. I have the Annual Unlimited with VDBv1, Panv1, V3, PanV3, V3Pro, OG S, and OG T cams.
