Disconnect movement on Cam Pan 3
Is there a way to turn off the panning on Cam Pan 3? Setting waypoints doesnt seem to work, and cam sometimes decides to point towards ceiling or other blank spot. I’d be happy disconnecting all movement.
Yes. When viewing the camera in portrait mode, on the row of command icons below the camera image, swipe left to get some more icons. Two of them will be “Track Motion” and “Pan Scan”. Either or both of those can be turned off.
Sorry it took me awhile to get back to you and thank you for the reply. Soemtimes seem like they’re simple, but if you can’t figure it out, they’re not – so thanks.
