I have a Rule that is set up to make a camera siren go off if motion is detected on the same camera. I do not want the rule enabled all the time, just sometimes. Every time I go in to either disable or enable the rule, I get a pop up notification that says “The trigger and action are for the same device. Are you sure you want to proceed?” and I have to hit Proceed. Like, yeah, duh I set up the rule. I’m aware. Why does it have to pester me with this notification every single time I want to enable or disable the rule? Can you guys stop this annoying notification or give me a checkbox to disable it for the future?
Thanks
[Mod Edit]:Title and tags modified to enhance search clarity.
I agree. The first time is great for a simple reminder. But after that it is a bit tiresome. There are infinite possibilities for Rules being triggered by and actioned on the same device.
That’s a good idea. My hope with a feature like this is that it’s a setting that would be remembered per Automation (vs. globally), because I can imagine use cases like those illustrated when I might be enabling/disabling routines and not want the reminder every time, but I wouldn’t want the reminder disabled “globally” for all future Automations I might create (unless that was a separate option in the app settings for users who might want that). I’m just glad Wyze Automations offer this at all, because Google Home’s lack of self-referential triggers is frustrating.
