So I purchased the switch and happy with the functions. I wanted to use some automation to have the switch turn on when motion is detected from a camera. I was able to set this up but quickly realized that the switch would not turn off.
I was hoping that there would be an add to the triggers that when the camera no longer detects motion you could control the switch.
I used this on another system to have different lights turn on and off with motion for security purposes.
Also, a delay would be beneficial. Like, if no motion is detected for 15 minutes (for example) turn off the switch or turn off switch in 5 minutes after no motion is detected. A delay turning on the switch when motion is detected.
Hopefully this is in the works or can be in the works to help with home automation?
