I saw a Youtube video that showed a sticky tab in the box. I was hoping to mount with that. Did Wyzy do away with that?
I never used a V1, but all my V2s and V3s came with a 1.5" metal plate and a double-sided sticky ring. The idea is you would stick the plate to a surface, then magnetically attach the camera to the plate. Then you could easily take the camera down without disturbing the tape.
I actually don’t use their tape, as it is too good. I use 3M Command Strips that are easier to remove when you want to later.
