Device List Filtered / Sorted by Tabs
I wish the Device list had TABs at least for the most common types of devices. Having to scroll down the whole device list to find a device is kinda lengthy. I’m not a power user and already have around 60 devices on my list. See attached image to get an idea of the tab oriented device list. Maybe we can fit 4 or 5 tabs across the top. You tap device and then tap your subcategory.
I like the idea. Make sure you vote as well for your Wish as one is not added automatically.
I will be voting as well.
I will call this a Feature so that we can select the type of devices to show on the Device Tab, similar to the Events tab.
I like this idea, too, and I’d like to see horizontal scroll in that strip (to allow for more than 4 buttons or tabs) and maybe labels that align with the categories that show up in the app when adding a new device. Tapping a button or tab should act like an automatic filter, similar to the Events tab, as noted. :+1:
This type of feature should also be “smart” enough to know what kinds of devices a user already has associated with the app/account. For instance, someone who doesn’t have any Wyze Plugs should not have a “Plugs” tab visible at all on this screen.
This is a cool idea, and it’s similar to the way I can filter by Device Type on the Devices screen of the Alexa app. I find that I use that feature quite a bit to make finding specific devices easier.
For this topic, I’d suggest a couple of things:
  1. Add an app tag, because the request is for changes to the app.
  2. Change “Sorted” in the topic’s title to “Filtered”, because I think that’s what the request really is.
Done. :slight_smile:
I added Filtered, but left Sorted as well. Figured some may want all of the items displayed but simply sort it by Type, Name, etc.
Devices Sorted by Room.
Amazon and Google do it. It seems to be the standard and make the most sense in my dumb brain.
And, the simple ability to sort Automations. But I digress.
This for sure. That’s a different request, I think, but it’s something I’ve wanted (and mentioned more than once in the Forum) for a long time and is long overdue.
Alphabetically sort Devices list in Wyze App 3.x
How do I automatically sort the Devices list alphabetically, using version 3.11 of the Android app?
When you have a hundred+ devices, it’s ridiculous to have to manually sort by drag/drop! Before the Favorites list, we would manually place ‘our favorites’ to the top, What’s the sense of having a Favorites list when you have to manually sort 2 lists now! It used to sort the devices automatically by default, now it’s gone.
PLEASE give us a method to sort the Devices list - it would please (almost) everyone to offer it as on-demand, with options to sort by Name, Device Group, or Date added.
[Mod Note]: Your topic was merged to this Wishlist request for consistency in grouping similar requests and for better visibility to Wyze. Please remember to scroll up to the top and click the VOTE button to show your support.
