I updated my IOS to 18.5 and then I noticed that my Landscape full screen display had changed. So I went to check my two other cameras and found that one was wigging out like the detection zone was not working. It took hours for me to get them all set up but two of them do not have tracking…just a static entry point view. The third camera …our front house and driveway view has always had a detection area set since we realized that the camera would shift the default view left or right with the tracking. So we set a detection zone and tapped the tracking icon under the live view screen and wala it worked for months. Then the major update was released in May and boom messed up as it deleted all our settings. Finally got that working until I finally updated the IPAD yesterday with 18.5 version. As I tried to reset the detection zone it was having major problems. I finally got it…quickly using arrows to get the default view and quickly finger sprinting to the detection settings to SAVE them. I had to break the area into up/down and left/right because it would reset before I was done. SO I did the up/down first, and then the left/right. I tapped the tacking under the Live screen and it did not turn green so I tapped it again. Normally I would get an alert about the detection zone area, but I did not get it. Then I went to the Detection Settings and found them on, but when I went in the slider (showing Green/enabled was unavailable. So I exited out of settings and went back to the cameras live feed and it was shifting again. I went back to the detection settings and this time it showed OFF to the left of the arrow and when I tapped on the arrow the detection settings screen showed the toggle switch off, and tapping on it gave no response. No enable or disable and the screen below the toggle was COMPLETELY WHITE/BLANK!
We reset the camera with the off button and by unplugging it, uninstalled the app multiple times, removed the app and turned off and on the Ipad, and Factory Reset it multiple times. A google phone can enable and disable the dectection zone but we cannot change the detection area itself…in fact, the detection zone is like 1/3 smaller which is really weird, so we deleted the google phone app and factory reset the camera, deleted and reinstalled the app and turned off and on the Ipad just in case. The first time we did this and reset up the camera, the detection zone toggle switch was available and worked but setting the detection area was difficult again with the camera resisting placement. By the time we got it set and enabled the tracking…the stupid toggle switch was inactive/non=responsive again.
Is anyone else having thee issues??? Before this update we used the detection area with the tracking flawlessly and we were told by tech support that this should work the same. What good is a camera that won’t move to look at the person walking right in front of it but not move to watch where they are going…LIKE TO OUR FRONT DOOR!!! Obviously the IOS update caused some issues, but I think the Firmware update is also part of the problem. Anyway, sorry for the length but thought specifics were important. Love to hear from anyone who might have this issue, and maybe even got feedback or a fix from tech support. I still do not understand why once I reset the app and factory reset the camera it no longer fixes it. GRRRRR! lol
