Design weather cover for camera
Our community has homes with cameras that are mounted above the garage by window ledges that do not provide cover from the elements. The holes in the back of the camera are exposed to moisture which i assume will effect the longevity and performance of the camera. Would be nice to create a flexible cover to protect the camera and maybe disguise it. I created one out of plastic gutter corner and wanted to pass along.
I have photos but does not look like option to include. Can provide if interested.
There are tons of covers for some of the cams available. Mostly the WCO and the V3 is what I have seen, a lot of either plastic or silicone covers.
There are but none of the clear dome or visor type fits the application. Unfortunately I can’t include pictures.
Different cameras have different housings/cover. Which camera model?
Welcome to the Forum, @thenelsongang4! :wave:
There is, and even as a new user you should be able to include those, though initially you’re limited to one image per post:
Good idea considering the location and what you want to view. :smiley:
I’m not sure what you mean, because it appears that you did upload a photo. :confused:
I was able to figure out how to upload one.
