Setting up my sixth camera and it won’t power up. It seems to be a defective adaptor.
Anybody else get a bad adaptor out of the box?
Can I swap it out with a regular cam adaptor or is the pan cam a different voltage?
I’m hoping Wyze will send me just a replacement adaptor.
I think the brick that comes with the pans are 5v 2a out? Check the brick, it’ll tell you what it is. Have you tried using a phone charger or any power brick that has those same out ratings?
