Once and for all, is it possible to choose the notification sound for the v2 as of this date? If so, how? After extensive research, I would say no, but I would like a definitive answer. BTW I use the latest Beta app, and firmware and am familiar with IFTTT. Thanks so much!
If you are using an iPhone (iOS) the answer is no. If you are using an Android the answer is still no via the app but there are 3rd party apps that can accomplish it.
I will have IFTTT set to do text messages, with the notification sound chosen within the Message + app. But I wondered, absent the text messages, if I could get a custom sound another way. Could you recommend another third party app? (Thanks so much for your help!)
The following thread had some good info.
