Creating a rule for floodlight pro to trigger floodlight causes the floodlight only to work when triggered
Creating a rule for floodlight pro to trigger floodlight causes the floodlight only to work when triggered.
After I set the rule I can walk right in front of the floodlight and it won’t light up. Only when I walk in front of the floodlight pro will it come on
I’m not sure if you’re asking for help or sharing your setup. What issues are you experiencing? Sounds like you want both floodlights to trigger the v1 floodlight when they detect motion, but it’s causing the v1 floodlight to not detect motion?
I can’t help with the Floodlight V1, but I experienced the same instance on a V3Pro.
I created Rules for the V3Pro spotlight to activate on motion from 2 other cams, a V3 and a PanV3. After that, the V3Pro spotlight refused to activate when it detects motion.
I had to create another rule for the V3Pro to activate its own spotlight on motion.
Nice workaround
It sound like if you set one rule you have to set a rule for everything. I may be not explain this well but if try it you’ll see
