I really don’t understand why there is no countdown timer on the Bulb Color? The standard Wyze Bulb has a countdown timer and I use it all the time. I would buy and use the color bulbs if they had this OBVIOUS feature. Schedule is way different than setting a light to go off in 60 minutes or whatever you want…#dissappointed in wizen on this one. Furthermore, I am getting the impression that there is no plans to add to one ofd the future updates!!! Urghhhhh!!!
I haven’t thought about that… Strange that it’s on the bulb but not the color.
Just thinking of workaround options. Do you have Google or Alexa to set a timer? I just asked Google to turn off my Family Room (color) lights after 3 minutes and it worked well.
That’s a great idea. I’ll try it but I would still like to see an in app countdown. Thanks.
Agree! Seems like a no-brainer, as they say. Might want to add this feature as a Wish List forum post to get some votes going. I’d vote for it.
this was brought up during testing and its something I’m quite surprised hasn’t been implemented yet.
Hi Bam
Yes it’s so shocking to me that it seems like a total oversight that will be corrected with a future update. I sure hope for that. For know I use a google assistant shortcut that seems to get it done mas o menos
Stay Healthy
Mark H
