Cordless vacuum hose hack
Just wanted to share this helpful hack to get more use out of the cordless vacuum. I was able to find a hose that fits in the hole of the vacuum with the help of duct tape to creat a tight fit. Now I can use all sorts of accessories and use it in my vehicles. It’s much easier to get in tight spaces.
I am looking to do this same thing. What did you find that fits? Will a standard 1.25 inch vacuum hose work?
