Convert to hub based?
Need some guidance, please.
I have a bajillion Wyze products at two homes. At one, I have the old Wyze door sensors which piggy back on my Wyze Pan Cam. Lately, one has been going stupid on a regular basis despite resets, camera power cycles, new batteries, etc.
I’m considering moving to a Wyze hub-based system, so I can also use temp monitors and leak alarms. However, I don’t want remote monitoring.
Can one use the hub system with door, temp and leak sensors without paying for monthly monitoring?
Apologies if this is very blond of me to ask
DEHolz
Yes. I don’t use many Wyze sensors, but they do work without monitoring, depending on what you want to do. I use mine for automations (solely motion sensors at this time.)
As Wild Bi;; said, all versions of the Wyze sensors can be switched over to the Wyze Hub. I switched mine over a few years back. I no longer have a monitoring subscription and the work fine.
I think you will have to reset them one at a time to move them to the new hub.
