I have been a Wyze fan since the beginning and own many cameras, plugs, bulbs, and a scale. I have tried chat support and phone support, both failed. I logged into the Wyze Discord server, but it was dead and no one talks or replies in there.
I have my computer monitors plugged into a Wyze plug (pre-2021 model). The power went out recently, and I cannot get it to re-pair with my network.
I am using the Android Wyze app, and I know it works because I was able to get all of my Wyze bulb whites to reconnect.
I also know the 2.4GHz network works because it is the same one I am using for my 3 Wyze Plug whites that all connect and work perfectly.
My Wyze plug (pre-2021 model) enters pairing mode (the light blinks quickly) and I can go through the whole process of setting it up in the app, When it gets to the “connecting” part that says it may take a minute, it fails, and nothing I try will make it connect.
And yes, my Android Pixel 9a is connected to the same WIFI network that I am trying to connect my Wyze Plug to.
I have rebooted my router.
My plug is within 6-10 feet of my router, which I have configured myself and the network works perfectly with every device except this plug.
Any advice or assistance is greatly appreciated.
