Wyze lock worked perfectly with my front and back doors. The outside lock for my workshop was not compatible. The two holes for the screws holding the unit together were too far apart and would not fit the Wyze attachment plate. I have tried a Quick-Lock and a Schlage from Amazon and both had the exact same incompatibility. They were the only brands listed on the Wyze site that claimed to be compatible with the Wyze lock. I went live to the local True Value store and non of the locks they carried were compatible. Where do I find a compatible out door lock for my workshop that will be compatible with the Wyze lock hardware?
Related topics
Topic | Replies | Views | Activity | |
Lock compatibility with Schlage Entrance Mortise Lock | 0 | 557 | November 20, 2022 | |
Smart lock compatibility | 1 | 282 | August 26, 2020 | |
Deadbolt with existing keypad inside adapter | 0 | 319 | March 13, 2020 | |
Wyze Lock Compatibility with Baldwin Deadbolts | 8 | 1007 | December 17, 2020 | |
Bolt lock in app not working outside of home | 1 | 679 | November 21, 2023 |
