I would like to add multiple “IFs” to my wyze climate sensor. Here is the situation. I am using (2) climate sensors and (1) Wyze plug to control the blower on my wood stove. 1 sensor is across the room and the other is directly next to the stove. I would like the sensor across the room to turn on/off the blower only IF the sensor next to the stove reads a temperature of 80° (or whatever temperature I see fit) which would indicate the wood stove is actually burning. This will prevent the blower from turning on when the stove is not being used on warmer days or from continuing to run when the fire burns out.
