That’s an interesting point I have overlooked up to now, but you’re right, it makes sense. I had wondered why most IoT brands (not just Wyze) don’t have a simple way to change the Network for Smart devices without going through some kind of set up again. It seemed like something so obvious…all the phones, tablets, laptops, desktops, etc make it so easy to switch networks, but almost none of my other smart devices make it so convenient. What you just said makes it make so much sense! devices with screens have a built-in UI where we can just click and select a new network, but any other smart device has to basically already be connected to the internet in order to switch to another WiFi, and that isn’t usually an option for most people who just barely switched routers or SSID’s…you’d have to do the switch on them all BEFORE the change takes place. Interesting. I really appreciate you pointing that out, @K6CCC --I had wondered why nearly no IoT company makes it easy to switch networks unless the device has a screen/menu. Now it makes so much sense.
Having said that, Wyze (and other IoT companies), could make it possible for us to select a bunch of devices at once and tell it to switch all of them to a new SSID/Password. That would leave us the following ways of resolving this issue:
- If switching to a new router, we could leave the old router active while we setup the new one, then once the new router is active, we can tell all devices to switch to the new one instantly, all at once. Awesome solution
- If changing the SSID/password, then before we make the switch, we set all devices to use the new SSID/PW and they will suddenly all go offline as soon as that setting is changed. Then we change the SSID/PW in the router and as soon as the devices see it, they will come back online. Another easy solution.
- If we’ve already disabled the old SSID/PW, and have the new one installed and then realize we need all those IoT devices switched over, we can load up a temporary hotspot SSID on our phone/computer to broadcast the old connection for all the devices to use, then give them all the new SSID/PW all at once. Then we can remove that temporary Hotspot and everything will be on the new router/SSID.
All of those options will work. I hope that’s what Wyze is working on setting up (select all the devices we want switched to the new SSID all at once).
Anyway, thanks again for helping me finally realize why basically none of my other IoT companies offer easy WiFi changing. Some of them even make me totally delete a device and set it up from scratch. Very annoying. At least Wyze doesn’t make me delete a device or lose all the settings and rules I have attached to it. I just have to go through simple setup to give it the new SSID…which is still annoying, but not as bad as some of the companies I have devices with make me do. Still, I am excited this is now “In Progress!” I want to be able to change my SSID/Password because there are some people who know it that I would like to prevent from ever accessing it with anything again, but I don’t want to change the settings on over 200 devices, so for now I instead monitor all new connections and just block anything I don’t recognize.
