I was able to set my Wyze cameras up on wifi but now I can’t connect to them on wifi. It always fails at some point, sometimes with error code 20011 and sometimes with no error code. Sometimes I make it as far as step 3/3 and sometimes it fails sooner. But it always fails.
If I turn wifi off on my phone, sometimes I can connect to the cameras but that’s not how I want or expect this to work.
I have no problem connecting to Ring, Blink, D-Link cameras, or any other devices over wifi in my home. Only problem is connecting to Wyze.
Any suggestions? If there isn’t a simple fix I’m not investing a ton of time tinkering with this thing. There are way too many other options that just work like they are supposed to.
Cameras have latest firmware, I have the latest Wyze app update and my Android phone is up to date. Wifi strength is 81% according to the app. I have restarted the cameras countless times and I have force-closed and restarted the app countless times. I have not deleted and re-added the cameras from the app and I’m not going to do that. If that is a fix once, it’s going to be the fix countless times in the future and I don’t want to keep jumping through that hoop. If this isn’t a stable platform, back to Amazon the gear will go.
