i received a replacement v2 because my first one failed to connect after successfully having used it for a while. i can’t get the brand new cam to connect to the internet either. i have power cycled, factory reset and flashed the firmware. additionally, it audibly states “wifi connected”, but that’s a fallacy. i must be doing something right, because i have other cams that are working quite well.
hey @18wheelz, I would recommend you check out this link to see if it can help you out, and if not please let me know.
https://support.wyzecam.com/hc/en-us/articles/360022258632-Connectivity-Troubleshooting
ok, i’ll work on it.
