Everything is working fine except this one function.
Whenever I try to apply no-go-zones by selecting “OK” the app goes blank and returns me to the Home page. The no-go-zones I marked out are gone.
I’ve tried:
- reinstalling the app (after an uninstall and phone reboot)
- resetting the vacuum to factory settings
- deleting the vacuum from the app, then adding it again
- updating to beta versions of the firmware and app
Is this perhaps a fault with the device, or is there something else I can try?
R.Good
Welcome to the forum @ChrisDay.
What mobile device are you on?
If you are connected to your home wifi, try disconnecting from that and connecting to mobile data and setting the no-go zone.
Seeing how you have the latest Wyze app (assuming beta since you are trying the beta FW) and beta FW. The above is just a curiosity suggestion.
Hi I am having the same issue here, very annoying as the robot keeps getting in wires or cat’s food bowl… please, did you figured it out?
