I’ve got cam v2. Is there a way to bulk delete events? I’ve got a ton of short videos and I don’t want to delete them one-by-one.
Thanks!
Thanks!
Great! Thanks!!
Be sure you scroll to the bottom of the list before engaging the edit pencil. That way you get the option to delete more than just the first 20 clips. ![]()
And my standard question - why delete them at all? They go away automatically in 14 days, and it’s easy to see that events are not current, so why bother to delete them?
I get hundreds of events every day (no, they don’t alert me). There is no way I would take the effort to delete them manually.
You do remember one of the complaints from Wyze was the large number of events people get and never view, right? That was one of the reasons given for the CamPlus/CamPlus lite fiasco.
And you do remember one of the complaints from Wyze customers was the notifications worked less than half the time, or that detection zones worked less than half the time, or that AI Tagging worked less than half the time, or that motion activation worked less than half the time. I thought these were the reasons to subscribe to CamPlus/CamPlus lite.
Perhaps if Wyze worked properly more than half the time I would be inclined to record cloud clips less than half the time.
Yes, among the many reasons I’ve stopped purchasing Wyze products. Moving back to Amcrest cameras and NVR for now. I’ve never been a fan of wifi cameras so I’m going with POE.
