Can the door lock’s open-door alarm be turned off? Sometimes I want to leave the door open,
Yes, when you are within Bluetooth range of the device, open it then after the lock connects to your phone go to Settings and then Alarm Settings. You can configure it how you want it there. Maybe also consider changing the Volume settings for the alarm.
This is one of the few settings that can’t be adjusted remotely through WiFi though.
Personally, I don’t understand why some settings require Bluetooth. I use this lock on an office and it’s weird I can’t change some of the settings through WiFi when the lock has internet capabilities.
Be aware…leaving the door open with the lock will drain the batteries much more quickly depending on how you configure the lock. I don’t use autolock because I don’t want the deadbolt locked during the day.
Thanks!
