Can only disarm Home Monitoring from iOS device, not on Android
Hello, recently when trying to arm my home monitoring on my Android devices, it does not work and displays a “Home arming failed" error. It works perfectly fine on my iPhone. I have cleared cache and made sure the app is updated. It is happening on both a Pixel 7 and a Galaxy S23. I have tried many steps from both Reddit, Google, and even here on the forums. Thank you!
Welcome to the Forum, @gnad! :wave:
What has Wyze Support said when you contacted them? Also, what version of the Wyze app are you using, and what specific Android version are you using? There have been some recent reports of problems from users who are on Android QPR beta releases, so I’d want to try to eliminate that as a factor.
Thank you
I have contacted them and I was told that they were escalating it (I have a ticket in their system). I made sure to update the app and double checked it was the most recent version as of 2 days ago. It is Android 17 (no beta), even before the recent update, I have never used Android beta.
Thank you!
