Since earlier this week, I can no longer make a secure connection to my camera through the latest version of the Wyze app on Android while connected to ProtonVPN. I can connect fine by disabling the VPN connection. Is anyone else having similar issues?
Nope don’t use it,thats a 3rd party software and not supported, i would disabled it
If you search the forum you will see that some people have resorted to configuring split tunneling to get Wyze to work better with their VPN software. It shouldn’t be necessary though.
If you live in an apartment then you might need it,we never use VPN due 2 we need to see l devices at a sits 24/7 good luck Tom V.P.Marketing
