Can I stream my Wyze feed to youtube? I have a Wyze Cam Pan.
There is no native support for this, but there are many workarounds.
You could use an open source project called “Wyze Docker Bridge”, which allows you to convert the Wyze cam stream to RTSP, RTMP, and many more which could then be streamed to YouTube using OBS or a different program, however this requires some technical knowledge and patience so isn’t for everyone.
You can add to that the wz_mini_hacks. Also requires some technical knowledge.
