Hi I would like to see what my camera see from a Chrome OS is that possible?
Not presently, but hop over to these posts and VOTE for them at the top of each:
Also, if there’s an Android emulator available for ChromeOS (I don’t know if there is), then you could install the Wyze app or TinyCam in that and view them that way.
Newer Chrome OS devices can work with many android apps natively. Have you tried?
thank you I will try but my Chromebook is not that new will see if it works
Which one is it? Google the model and something like “enable play store” or “Android apps”. Some of the older ones work but are a bit buggy and the mode needs to be enabled since it isn’t on by default.
I would like to see what the camera sees from my chromebooks any of them I have 3 different ones.
You can view the cameras on a chromebook. I have a Acer Chromebook R11 and use TinyCam Monitor. It works great so far. Just download the google play store, then download tinycam monitor pro and follow the instructions. It works great!
