I currently have a Trane thermostat that goes with the Trane AC unit and Trane XR heat pump. Having trouble with the set up and understanding what i need to tell the app i have. It says i have a compatible system, but i’m learning that my wiring may be a little weird just because it’s a Trane system. Main issue is figuring out the heat pump and what to tell the app i have since it’s looking for O/B and i have them separate O and then B (see picture)
I’ve seen some say the B wire is like a C wire, but still very unclear.
Top: Y2 W2 G W Y (R and Rc) so RC according to app
Bottom: X2 W1 G O B Y (R and Rc) so assuming Rc
I think i just need to figure out what to tell it because it’s not letting me move forward with the “preparation” stage.
When i put what i have It says it’s incompatible…
I’ve seen others have some success but unsure with my specific situation.
Thanks for your help in advance!
