I have 2 v2 and 1 Pan and I can set event recording for motion but after 20 hours or so the cam just “rejects” on motion setting thus recording nothing. Has anyone else experienced this problem or is there a solution that I’m not utilizing?
The cams are for checking in on my animals and their caretakers and I can’t get them to stay in the setting.
The settings are changing. The slider is back to default position but the push notification slider is still selected. It just happened again. It was on and recording at 4pm EST but at 10:30pm EST it was no longer recording on motion.
Settings Changing back by themselves Is not uncommon I’ve had it happen with several different settings Not happening to me right now though .Not in quite a while
Did you try uninstalling and reinstalling the app
Try killing the app first Then opening it And setting the motion Detection on.
Try restarting your phone too But anyway, You should probably send a support request With logs
Are all you cameras doing this or just your Cam pan Because I was playing with my Cam pan that I don’t use that often And it wasTurning motion detection off on its own
