After Add device–> Cameras, there is no menu item called Wyze Garage Door Controller
Welcome to the user-to-user forum, @Neal33 !
Should be at the very bottom if you have a current app. ![]()
You can also search for it before going into Cameras.
That was the problem. I always update the firmware but never noticed a prompt to update the app on Google Play. After update the menu item was right at the bottom in Cameras. Thanks
