Camera Snooze Notification Settings
Is there a snooze a camera for 1hr on the phone? I can’t find it.
I see it on my apple watch but when I select “Snooze All cameras for 1 hour” or “Snooze this camera for 1 hour” it doesn’t work.
I keep getting a notification when someone is working in the yard.
On android you can snooze notifications, that is a function of the OS and not the app though. It snoozes them for all cameras since it is snoozing the whole app and doesn’t know the difference between the cams.
Look through the options in automations, there might be something in there that would work. I can’t recall if there is a “turn off notifications for x hours” option or anything like that. But if there is, you can just place a shortcut to that on your home screen and tap it when you need to.
Are you potentially using one of the notification manager apps that is out there? It could be that is what is giving you the ability (or making it appear that) you can do it, but maybe it is a feature of the IOS app, not positive, haven’t used iOS.
There is a snooze for 1hr option on my Apple Watch but that feature isn’t working. Maybe have posted about this but no fix.
There is no snooze option in the Wyze app that I could find.
I didn’t want to rely on the OS to do that.
Closest thing I can see in the app is automation shortcuts for “turn on notifications” and “turn off notifications”. Could put a shortcut to both on your home screen (well I can do that on Android, not sure about iOS). Obviously not ideal. Off the top of my head I can’t think of a way to automatically trigger them to turn back on after 1 hour.
As far as the feature on the watch, wasn’t aware they had done that for Apple, no idea if there is a fix or if they’re aware. Maybe try submitting a log and opening a support case?
If you use the Wyze app on your phone. Click the bell in the upper right corner there are these options:
