Camera plays a sound (eg. siren) on motion or on demand
This is on my V4. Have you updated the firmware of the camera?
I’ll try that thank you for replying. The camera will be used either way. Im a big fan of the wyze cameras
The only other thing is I wonder if you need Cam Plus for verbal motion warnings??? I would need to dig into the documentation to see if that is the case. I have Cam Plus.
:point_up: This is my thought, too, especially since you said this:
If it still has the firmware version that shipped on the hardware, then you may need to apply firmware updates in order to see that feature, as Wyze tends to add things over time.
Nope. I’m not a subscriber, and I see this feature on my Cam v4s.
Also, I’d note that when I navigate from a Cam v4’s Live Stream screen to :gear: Settings ➜ Detection Settings, the resulting screen (where I see the Motion Warning option) says Detections at the top and not Detection Settings. I don’t know if this is another firmware-induced change or not; my other cameras say Detection Settings on this screen.
Hi everyone,
Thanks for the great advice. All that was required was indeed an update to the firmware on the V4 and I now have voice alerts working.
Thanks again
Wyze Cam Battery Pro Motion Warning
I wish these battery cam pros had the ability to add a motion warning like my video doorbel v2. Kinda silly that one fit he most expensive and advanced Wyze cameras doesn’t have that ability. Any way it can be added?
[Mod Note]: Your topic was merged to this Wishlist request for better visibility and consistency in grouping similar requests. Please remember to scroll up to the top and click the VOTE button to show your support.
Motion Warning for Battery Cam Pro
I have 3 Wyze battery cam pros and would love to see a motion warning feature on it like I have on my video doorbell v2. Is there a way to add this?
I think it would be great for deterring thieves like my doorbell does.
Use the spotlight. It will at least let them know they are seen. They won’t be adding that motion detection warning to those cameras.
They rarely add anything to the wishlists of things that are posted here. Great ideas too but alas, no new features. Most things get a tweak but then are abandoned and no new innovation is introduced on them.
