Cam V4 continuous recording
I just bought the V4. Formated my Sandisk V30 128gb, have it set up for continuous recording but when I got the main page in the app, it only show recent events recorded. No where for continuous recorded video. I have tried everything from reformatting, turn off and on. Need help.
Welcome to the Forum, @drmorgan2217! :wave:
On Cam v4’s Live Stream screen, you should see a strip of controls (the “menu bar”) beneath the live view pane. One of these should be  SD Card. Tap that to display the full microSD card recording timeline, which you can scroll, pinch (zoom out), spread (zoom in), and tap to view your recordings. If you have continuous microSD recording enabled, then you should see an unbroken green strip on this timeline.
What he said:
The others have covered it, just want to re-iterate that events are totally separate from the continuous recording. If you go to the SD card screen, you’ll see the continuous video (with event tags on the timeline also, but you’ll see the solid green line between events, which would not be there if you had it on event only recording).
