Cam Pan V1 doesn’t work
I have a cam pan v1 I’ve had since the beginning; for the last few months it’s been sitting with a yellow solid light. I’ve recently changed isp but the issue was before hand. I think if this is a reset button on the bottom it may be broke. Any suggestions?
What have you done to try to fix the problem? Presume you have unplugged power and reapplied to reboot? Is there an SD card in the camera? If so, power down the camera, remove it and reboot. Another option is a manual firmware update/reinstall using an SD card.
What makes you think the setup button may be broken? Can’t tell anything from the video.
Just plugged and unplugged. No SD card, I’ll have to get one and see if that method works. So there’s the setup button and something on the other side I thought might be a reset button. It popped on day when I pushed it and that didn’t do anything but prior to and after, holding the setup bouton does nothing
I had a similar problem with the same model and ended up throwing it in the trash after all the common troubleshooting failed. Notably the reset button did nothing, meaning I never responded with READY TO CONNECT. It also developed an image quality issue, displaying a yellowish haze.
Trash it,get the V2 PTZ a big improvement, we gave our church our 6 old ones
The setup button IS the reset button. I need to look at my cam and see what the other side is.
On the other side on bottom is the mic
